section /elevation marker direction
Is there by chance any way to choose left - right direction of your section / elevation marker?I can only see upward/downward direction option.
Archicad project in v24, transferring via IFC to consultants in Revit using Improved IFC Import Add-in.Custom built GDL door objects to suit the standard manufacturers door suites in AUS. In Archicad:The outside of the door frame aligns with the out...
Hi everyone, I am trying to answer some of the questions of my team regarding information take-off, specially all that is related to walls and façade. Regarding inside walls and partitions it all comes down to the fidelity to the real construction, m...
Hello.Is it possible to select objects on all floors, being on the plan of the 1st floor?For example, a table object is located on the first floor, and its copies are on subsequent floors, can I select all tables not from the 3d view, but on the plan...
Good day everyone, When exporting MS Excel spreadsheet reports from the Issue Organizer in Archicad,only the headings in the issue organizer are exported. Data such as comments and marked up views of the individual issuesare not exported. Would there...
Hi -Since we don't do too much output of dwg files to consultants, I freely admit my questions here may be rudimentary. But any experienced advice would be appreciated. So just to be clear in what I am asking, as a starting point, our structural cons...
Is there some way to prevent this besides exploding the drawings first? Perhaps I have some setting in the Translator configured wrong ? For example, I joists objects that have been stretched to 20' will all be at the default length in the .dwg. Show...
Archicad 24 seems not have the features presented in the EcoDesigner Start workflow in 2014 (EcoDesigner STAR Workflow: Building Energy Model Calibration 3 of 6 - YouTube) , features were removed. I was wondering if it is true or now they're hidden. ...
Hello everyone, Yesterday we encounter a special problem with our bimcloud basic server. All the project disappeared from the server. It seems that project manager lost contact with the project server. That happen on server for 23, 24 and 25 at the s...
I forced a user out of a project. A couple of days later he expectedly gets the “you are out of synch, save local as PLN or reload”, and when going for reload unexpectedly gets the “Archicad encountered an internal error, will now close”. This happen...
User | Count |
5 | |
4 | |
3 | |
3 | |
2 |
