Text Scheduling?
Is it possible to schedule text? we have several comments around our plans in a separate layer. It would be really useful to have those organised, but i am not seeing Text object as an Element Type anywhere inside scheme settings
Hi all, I have migrated a project from AC22 to AC23, and I am experiencing problems with a schedule not showing properties that worked fine in AC22. I have 4 curtain walls, each orientated differently, north, south, west and east. Each orientation I ...
Hi there, This question is for Graphisoft team. Few days ago, I rescued and old document for GDL standards that was published in year 2000, and I have found out that there few pages that were dedicate to a group of parameters with the "FM_" prefix, t...
Hi again. So we are importing an ifc and some elements were converted to archicad columns and beams and others are just objects (based on our ifc translator) Is there any setting I can tweak to make every ifc element converted to real archicad elemen...
Hi, I read information in the ARCHICAD Help Center Knowledgebase that : Sometimes the program [ARCHICAD] is slow because the Project contains lots of Groups (hundreds or even thousands of them). This can be caused by inadvertently grouping elements a...
Is there a way to duplicate a teamwork project? I would like to migrate a project from 20 to 23, but before that I need to check if everything is ok in 23. So I would like to test the project on a duplicate. Realted question: If I migrate a project f...
Can anyone help with an IFC problem. I have tried opening and also merging an IFC file into Archicad (v20) but cannot display the file in 3d. That is I can see all the information in 2d and can even generate sections but there is nothing in the 3d wi...
Hi, We have a project with 5 floors and we received an ifc from the structural engineers with 25 floors, because they work in a weird way. I looked for this but couldn't find an answer. Is there any way to import/merge the ifc into our archicad file ...
Hi, I am trying to save a ifs file and i keep getting this error "cannot write output file error" I tried : -saving as ifc and ifcxml -saving only 1 element of the file -saving with a simple name -saving in desktop, server and dropbox -rebuilding the...
I'm new to ArchiCAD and I'm following this video, with same dwg for external reference downloaded from here, but when I attach it, the Xref's drawing does not appear at all. I tried by drawing another dwg myself with an Educational AUTOCAD 2020 and a...
User | Count |
17 | |
6 | |
6 | |
5 | |
4 |
