PHILLY AREA MANAGER?
Are there any other archicad managers in the Philly area?? I'd love to get together and discuss strategy...
Hi,'How can I calculate total area of windows in the exterior walls divided by total net area of outside of exterior walls? I get a result only by using the one windows and wall area but it's the inside of the wall which is not what I want. When divi...
Hello everyone, need some help to setup bim cloud manager. When i have to Set Up Server Address i can't continue neither whit pc adress or ip adress. The massage is `CONNECTION ERROR` AND THST'S IT. Can ypu help me? Please
I am new to Archicad and I am having issues with the exported model. I have exported the model both in gbxml and IFC4 format to be used in TAS Engineering and Cype softwares. When I import the model, both softwares do not recognise internal partition...
When exporting IFC, is there some point of origin I can maniulate? We use this IFC as a reference model in Revit, but now I've: 1. lowered the model 2. rotated the model 3. moved the model If I update the IFC reference model in Revit with this new fi...
Hi all, We have quite big files on the Bim server, the are around 4GB, they get big after we hotlinked an IFC, and never deflated once we took the hotlinks off. when saving the PLN the files size is around 300 MB, does anyone knows how to deal with t...
Hi, Does anyone know how to create smart folders in the view map section like the ones created by ArchiCAD in the basic template? Thank you in advance
Im a bit confused with how the ID manager works, sometimes it works as how its been explained to me and sometimes it doesnt. When I was taught how to use this manager it was that you could select them in order, then use the ID manager to apply a chan...
Is there a reason why a flight of stairs gets counted twice in a Schedule, as type "Stair" and then again as type: "Structure (stair)"?
Hi, I've recently updated my Archicad to version 23 an ever since I've been experiencing a problem when attaching a Xref dwg. Before I click on the node to insert the xref I can see the outline of the drawing but after that, nothing happens... I've s...
User | Count |
18 | |
6 | |
5 | |
5 | |
4 |
