Editing Autotext
I used the orientation tag for my elevations. All I want is for the autotext to be capitalized rather than lowercase.
Hey, guys. Hope you're doing all right. I write this post to find a solution to a problem I encountered when exporting to DWG/DXF from archicad. The text in the elevation and section markers appears incomplete in the DWG drawing. Example: I have trie...
Hey, Me and my fellow students are all using ArchiCAD 22 with the student license. Now I wanted to create a BIMcloud to work on a project together. When I want to connect to the BIMcloud it tells that it is fixed to Version 20. Is there a way to chan...
Hi everyone, First of all, I'm a Dutch student so don't mind my incorrect English... Nevertheless, I still have a 'problem'... even after hours of research, I couldn't find the right answer. My problem is as follow: for my internship the company aske...
Hi guys, Firstly a caveat: I am new to the property manager so please go easy if I am missing some obvious things. I am creating a series of house and apartment type options. Each housetype is classified with a different zone number e.g. 25 and each ...
Wasted about a day trying to troubleshoot DWGs Xrefs (each some ~40,000 elements —large, but not huge) in AC 22 —repositioning them took 25+ minutes, bringing in both objects and lines, simplifying fills or not, teamwork or local, worksheet or story,...
I am writing an all inclusive keynote expression that generates text strings depending on element type. So far this is going well. One of the items in the string is an element's classification, which I have converted to natural language for this purp...
Hello, I'm trying to set up some company standards and favorites for a template file, but I've noticed some strange behaviour when it comes to layers and layer combinations and transferring between projects. I was wondering if someone had a best prac...
How does anyone produce a good example of a heritage or conservation roof light? The ones in A22 library are good but can't be made to sit flush with the roof as they should in historic buildings. Nor can the frame be made narrower. I am unable to lo...
Hi This may be the wrong forum, but I’m not sure where is best. I am unable to locate a good IFC model of a conservation roof light, and I must admit that this lack of manufacturers objects is the only frustrating feature of Archicad. It’s clear that...
User | Count |
6 | |
3 | |
2 | |
2 | |
2 |
