Collaborate forum
Forum Posts
Resolved! recommended add ons
I've read through a few pages on this area of the forum and got some ideas but would like some clarification or other suggestions. I work for a small residential firm. We do mostly remodels, some additions, and occasionally something commercial (stor...
Calculate using expression; Zone - columns
Hi, In Finland we have a regulation to be able to deduct certain types of columns from the main area (m2) The main area is calculated using a Zone that extends from the outer walls inner surface 250mm - so you have to draw the Zones by hand. We use t...
Multi-seat object, how to schedule count
I have a 'seat row' object, it has a parameter displaying the resulting seat count and it can show the count value in a text block. Is there any way of getting that object information into a schedule, so as to list and sum up the individual row count...
Ignacio by Advisor
  • 1215 Views
  • 5 replies
  • 0 likes
File size on BIMcloud22
hi, is it possible that a Teamwork file on the BIMcloud22 shows the file size including all snapshots (backups)??? One of our files has 6.7Gb and just by duplicating it (in BIMcloud) the file size dropped to 2.3Gb! The duplicated file does not have t...
agroni by Contributor
  • 1467 Views
  • 6 replies
  • 0 likes
Window Schedule : showing New Windows in Existing walls
Hi all, I'm trying to tweak my 'out of the box' window schedule to show only new windows. If I set the Renovation Filter to NEW it will only show new windows that have been placed in new walls. I need to also show new windows that have been place in ...
Anonymous by Not applicable
  • 1548 Views
  • 6 replies
  • 0 likes
Parametric Option Sets
I am having trouble with the correct associated Zone showing up in my door schedule for a location property, so I am working on creating a new property for doors in which there is an option set with all of the Zone Names in the project. Is there a qu...
SCHEDULES
Opened my door schedule today, started making changes in several columns. one being leaf thickness. Changed several doors thickness, no problem. Went for coffee, came back and continued to change several doors thickness but the schedule would not tak...
  • 1016 Views
  • 1 replies
  • 0 likes
window rate
I need glazed doors to be calculated into window area in zone setting. Is that possible?
  • 1280 Views
  • 0 replies
  • 0 likes
additional object parameters (AOP) in properties
Hi! I would like to know if there is possibility to extract data from additional object parameters (in further text AOP) to user properties? Those AOP is possible to be listed in schedule. In my example I would like to schedule window sill and board ...
  • 1058 Views
  • 1 replies
  • 0 likes
Resolved! Archicad 7 Zone analytical area calculation??
i m looking for a feature in archicad 22 that was available in archicad 7, where you could calculate the area of a zone but also break it down to simpler shapes dimensioning each one and producing a list with every calculation or each shape, with a s...
  • 12181 Views
  • 10 replies
  • 1 likes
