Collaborate forum
Forum Posts
Material thickness ifc
Hello, I have a problem exporting material thickness to ifc. The filter is okay - other models are exporting correctly with it, but one of the models export materials without any thickness (I can see materials, but their thickness is 0). Can't find w...
Ieva by Participant
  • 473 Views
  • 4 replies
  • 0 likes
IFC from Revit to Archicad
Hello.Maybe someone knows. I have an IFS file from Revit and when loaded into Archikad, all structures and objects are placed on one layer, but I need them to be placed on different layers.
ARCHICAD - SPECKLE Connector
Apparently, an ARCHICAD - SPECKLE Connector is in the works: https://speckle.community/t/archicad-connectors/1499/24   (The image is not mine, its original can be found in the above discussion.)
Resolved! Create mesh from surveyor's data
I am getting an error sound (but no error message) when I try to create a mesh from the attached survey .txt file. I have converted it from tab delineated to comma but no luck. Any help would be very much appreciated.
Importing the point cloud on the same coordinate system
Hi, I'm trying to figure out the most consistent way to bring a point cloud back in to a project on a different computer, and have it lay on the same coordinate system that it did before. Typically, when starting a project we rotate the point cloud a...
wbuzan7 by Newcomer
  • 321 Views
  • 2 replies
  • 0 likes
Doors, Bounding Boxes, GDL, IFC and Revit
 Archicad project in v24, transferring via IFC to consultants in Revit using Improved IFC Import Add-in.Custom built GDL door objects to suit the standard manufacturers door suites in AUS. In Archicad:The outside of the door frame aligns with the out...
2022-02-22 Sliding Door Solibri.png 2022-02-22 Sliding Door Solibri Opening.png 2022-02-22 Sliding Door Revit.png 2022-02-22 Sliding Door Revit Family.png
Quantity takeoff and model fidelity
Hi everyone, I am trying to answer some of the questions of my team regarding information take-off, specially all that is related to walls and façade. Regarding inside walls and partitions it all comes down to the fidelity to the real construction, m...
afaria by Participant
  • 409 Views
  • 4 replies
  • 0 likes
Selection of objects
Hello.Is it possible to select objects on all floors, being on the plan of the 1st floor?For example, a table object is located on the first floor, and its copies are on subsequent floors, can I select all tables not from the 3d view, but on the plan...
