incorrect calculation of polygon areas
Noticed the following error. When constructing a section of an element, a bent metal strip with initial dimensions of 265x1 mm2. When measuring the area of the object turned out 0.000185 mm2. This does not correspond to the area of 265 mm2. With ...
