Collaborate forum
Forum Posts
Resolved! Point 0 and North setup for BCF comunacation
Hi, I'm trying to set up communication workflow based on BCF. What I have noticed that BCF saved either from Kubus or Markup tool are not influenced by North setup in Archicad. After import to DDS or TeklaBIMsigth viewpoint, form comments show differ...
Anonymous by Not applicable
  • 973 Views
  • 3 replies
  • 0 likes
Classification of composite walls
Hi, Why is it impossible to classificate composite walls by layers? Is it any used method for this? Do ARCHICAD developers think about to make an option to explode composite walls in order to make it possible to classificate it by layers? Thank you f...
  • 3288 Views
  • 7 replies
  • 0 likes
.IFC gets wrong date after unzipping .ifczip
Hello, I don't know if this is a bug, but when I create a .ifczip file and unzip it afterwards, the date shifts one month in the future! So a ifczip file made on 12 march 2018 gets the date 12 april 2018 after unzipping. The file was tested running W...
  • 1029 Views
  • 3 replies
  • 0 likes
BIMSERVER 21 - Activities Panel
Hi All, i was checking the Activities Panel in a project and i see 2 activities from an user: "lock / unlock". Can somebody explain me what does it mean? i mean as it did. The user who did it is a restricted one. I don't see more information in Help ...
_Salmon by Newcomer
  • 1589 Views
  • 1 replies
  • 0 likes
Walls Problem
I can't discover how to apply the finish of the wall at the end of it. As an example, when I draw a single wall, straight with no curves, at the end it shows the core but I don't want that, I want to see it finishing with the plaster. I tried the wal...
  • 1661 Views
  • 2 replies
  • 0 likes
Which 3D Glasses?
I think I need to do a poll, to make up a decision i have to make Which 3D solution would you choose if you didn't want to stay with the Cardboard BIMx. If you have maybe a comment or another product to name, please do so I am thinking of simple (con...
agroni by Newcomer
  • 1352 Views
  • 0 replies
  • 0 likes
Create Schedule with selected surfaces only.
Hi all What is the command to only show specific line items in the output of the surfaces schedule? I have items showing up that want their attributes, but I don't want them to show in this schedule. I just want to shut off selected lines. Randi Fox ...
  • 1175 Views
  • 0 replies
  • 0 likes
