Cabinets and desks and other objects that you can resize in Archicad 25 are snapping back to there default size and shape and orientation when translated to DWG. Is this a common issue? Or is there a translator setting that I am missing? I have tried...
I create a master Attribute file whenever I make changes to my template. Then I can go into my project files and update their attributes to my standard. However, I have found that creating Attributes.xml file from the Attribute Manager on my M1 Max l...
Hi,I can't really find info on web. Is there a setting in Archicad that autolocks drawing elemenets, moving elements within certain length. For example 1cm when i am drawing or moving wall i want it to bet X.00 cm. I know i can type it but i dont alw...
We got confirmation that the upgrade to BIMcloud Basic has been discontinued.Graphisoft: this is a hugely boneheaded move on your part. And the first one that I've ever felt the need to rant about in a public forum.What are you thinking?We don't want...
Hi guys. I was wondering if anyone has a trick to have your newly created IFC Properties "Ticked on" upon creation. This way they would be a part of the Existing data export-setup... I see many users who creates Pset´s, after the initial proposal pha...
I'm going to start working in Revit in a residential architecture class I'm taking. I've only used Graphisofts Archicad up until this point. How do the two compare and what frustrating things can I expect to find in Revit?
A trailing snap box has been inadvertently added to my mouse cursor. Does anyone know how to turn off this feature? I would just like to go back to a normal pointer for the mouse cursor (without having the small trailing box follow my mouse movements...
Me wonder... We're a part of a national team creating a new basic Swedish standard for BIM and regarding stories we want to use Name for the numbering and Description for the "public name". Example: 02 Mezzanine where 02 is the number and Mezzanine t...
I have a hotlink module that has exactly the same layers as the Host Project.I have text in plan view in the hotlink module that has been placed on a specific layer.When the Hotlink module arrives into the Host Project the text in the hotlink module ...
User | Count |
17 | |
6 | |
6 | |
5 | |
4 |
