Window marker export
Hello, How can we export a window marker? I only find a import menu. Thank you in advance
Hi: I´m doing a two story project and creating a light list for it. I can't find a way to separate that list from one floor to the other. It just shows de entire amount of light fixtures from both floors. How can I effectively create a filter? and if...
I have been asked to add a 'contingency' quantity to a schedule, which is a percentage of the quantity in the model. So, for example, if there are 26 in the model, I need to add 4 as contingency, making a total of 30 to be ordered from the supplier. ...
Hi, I need a schedule with all my composite walls. Data needs to be ID, overall thickness, individual skin BM and thickness. I can't do that but suspect it's me...or? Suggestions appreciated. Mats
I'm using ArchiCAD 21 Trial version. Has anyone experience this problem? RFA and RVT Geometry Exchnage.apx is out dated. How can I update the file? Thank you.
Is there a way to adjust the spacing between columns / rows in a restructured schedule? At the moment, it is set to 2mm, but I can't seem to find where to change this.
Can you apply template settings to a project? The project has been started with the OOTB template, a few layouts have been setup and drawings issued but there are a number of elements and the continued design development that would benefit from the p...
Hi, I'm an landscape architect working in Archicad 21 and currently working on a projected where we collaborate with architects (Revit), exchanging via IFC format. My issue: When importing the architectural model, the IFC model displays top linked el...
Hello everyone, I am currently using ArchiCAD 21 to modell things for 3D printing of architecture models and everything was going fine till the actual printing procedure came. The printer used was PreForm Form 2. The problem is depicted in an attache...
Hi, How to export ArchiCAD 20 file to Solid work 3D software. We tried with .ifc format, but its showing some error. Reply please. Thank you, Roopa A
User | Count |
18 | |
6 | |
5 | |
5 | |
4 |
