How to remove redundant xref files
I need to clean up the list of xref files in the xref manager but I can't remove or delete old files. Where can I find a remove/delete button? Thanks
I subscribed to the Cadimage stair tool, only to discover that the "Timber Railings" are completely broken; the current version has no options available for selecting newels and balusters or adjusting them. When I reported this, I was told that it wa...
As in the title. Is it possible to create such schedule? With flexible duct lenght? I've created mechanical ventilation model using MEP modeler and it would be great if I could make such schedule as addition to the drawing. Or is there option to at l...
FYI: Today Archicad added 6-7 YouTube videos which describe the use of formulas in properties and therefore Schedules. This makes obsolete the necessity of using the difficult and quirky List Schedules to achieve the same functions. Well worth viewin...
How do we add users photos on teamwork dropdown. Photos are on Bim server. ?
Hello all, I have been trying to find a way to use my old Android tablet as a second input device as a programmable keyboard for shortcuts. I am able to get the tablet as any variety of remote access or remote keyboard inputs. But is there an applica...
Hi, 1,5 months old using Archicad 21. Could you please help me model purlin for roof in industrial factory, like attached picture. One more, I modeled these purlin in Tekla, and I export to IFC file, to import into Archicad. How can I insert these pu...
You are working on some specific corner with some weird scale, GOC and layer combination, after a thousand QuickLayers clicks etc., and in comes the damned TW message with a view capture. You know that when you open that capture your current custom v...
Hi all, I need to replicate the attached list, and I found most of the items under "parameters for listing" in the zone tool. The problem is when setting up the finish schedule I can't find the parameters under the "add field" button in the scheme se...
Hello, I got a problem with the window and door schedule. The floorplan and the elevation in the schedule are displayed incorrect. Also in the 3D axonometry the window is laying flat. See attached image. When i copy the building to a new file everyth...
User | Count |
18 | |
6 | |
6 | |
5 | |
4 |
