Collaborate forum
Forum Posts
overwatch server
My virus protection software (symantec) has taken exception to an executable file nesting in the Archicad 20 file. We have just installed the update. I assume it came from there. Would you chaps confirm that this is an ok file to run? Cheers Jo
JoWplan by Newcomer
  • 4029 Views
  • 0 replies
  • 0 likes
Speech and recording icons in Archicad 20
Hi, I get a speech and recording icons on the bottom right position of the main screen in Archicad 20. The recording icon pauses if an Archicad menu window is open. Sometimes I see a red cross line on the recording icon. The above icons appear only i...
Takis by Participant
  • 1829 Views
  • 1 replies
  • 0 likes
Teamwork server on dedicated machine
Firstly, does anyone run their BIM server on a dedicated machine? We're struggling with a fair amount of lag when opening, sending/receiving. So one of the directors has asked if there would be any benefit in a dedicated server machine which runs BIM...
tlodge by Newcomer
  • 1265 Views
  • 0 replies
  • 0 likes
Creating a Contour Line with Magic Wand
I'm trying to create a site contour. - I've placed a DWG of a site contour as a worksheet. - I made that Worksheet to Show As Trace Reference. - On the Ground Floor, I drew a rectangular mesh following the boundary of the site. - I selected the newly...
Lizara by Newcomer
  • 9573 Views
  • 17 replies
  • 0 likes
Archicad 20 to C4D
Hi When re-exporting an Archicad model to C4D (with Vray) for rendering, I've discovered that I cannot reference the previous file's textures, cameras, rendering settings etc. I had used the 'din3d' plugin on previous versions of Archicad (which was ...
emerich by Newcomer
  • 8723 Views
  • 14 replies
  • 0 likes
Super Slow DWG translation from AC19?
Hi everyone, Apologies if this has been answered previously however we are experiencing super slow DWG translations from AC19. I had not seen this with older AC versions (pre-AC16) translating much more complex drawings.... The Site Plan takes about ...
emerich by Newcomer
  • 948 Views
  • 0 replies
  • 0 likes
IFC base quantities
Hi there, I am looking for a solution in order to get the external dimensions of walls stored in the IFC base quantities. Indeed, the IFC base quantities are based on the wall center to center dimensions, so I am looking for a tool in archicad which ...
