Collaborate forum
Forum Posts
Fbx export
Fbx export doesn't consider each élément like a box, mesh or other By working with Unity it's not possible to create collider interactions between our model and Unity création
Collaboration bug
Creating a layer set is possible without having to reserve the manager. However, when a collaborator reserves the entire file, it becomes impossible to send the changes made to the BIM server. This conflict also exists for all other element creations...
Unable to open teamwork project
Hello! I was working on a teamwork project (Archicad 19), but when I put send&receive the file froze and I had to force it to close. After that, I haven't been able to open the teamwork project anymore. I get a message that says "Error occurred durin...
Anonymous by Not applicable
  • 3296 Views
  • 5 replies
  • 0 likes
ArchiSKETCHY alternative?
Hi to all who use and like ArchiSKETCHY for making presentation and schematic drawings look a bit looser and hand drawn. Now that I am using AC 21, I have found I need to purchase the entire ArciSUITE from Cigraph just to get ArchiSKETCHY. Communicat...
rm by Advocate
  • 989 Views
  • 0 replies
  • 0 likes
IFC 4 issue with Door type
Hello, IfcDoorStyle should be deprecated detract from IfcDoorType. (http://www.buildingsmart-tech.org/ifc/IFC4/final/html/schema/ifcarchitecturedomain/lexical/ifcdoorstyle.htm) Am I do something wrong with IFC2x4 Schema management in ArchiCAD 21 ? Th...
Cleaning Up Embedded Library
I've never figured out how to clean up the library, so let's start with something simple;) In the image, I have no clue what albero_sole.png is. It seems to be part of "Alnus Cordata parts (Do not modify)", which is something I'm pretty sure I don't ...
  • 2780 Views
  • 2 replies
  • 0 likes
incorrect View form Opening Side
What might be causing an incorrect View from Opening Side in my schedules? What is showing could be the inside view but that is not one of the Fields. ? The doors are placed correctly, and they do look correct in Elevation and 3D views. There is a wa...
CADImage uninstall
I downloaded the CADImage 30 day trial, it's now expired and I don't wish to purchase. I have deleted the program and restarted, Graphisoft have advised me to uninstall from my C drive. This is literally nowhere on my C drive. I keep getting a pop up...
  • 1805 Views
  • 2 replies
  • 0 likes
