Collaborate forum
Forum Posts
Make editable an xref’d DWG
We have a DWG file from a client for a site master plan. It has several other DWG files xref‘ed in toit but it has not been bound before exporting to us. Does anyone know a way to explode the DWG to make the entire file editable?
Resolved! Elevations, hotlinked module, extra composite appeared
Hi! I am working on a main model that has three buildings in it and the separate buldings are hotlinked in. I drew in a foundation plan for one of the buildings and then relinked it into the main model. This messed up the elevations, but I have manag...
Evaru by Contributor
  • 810 Views
  • 8 replies
  • 0 likes
Archicad => AutoCad Export problem
Is there to export DWG from Layout (where floor plan drawings are linked) as you would export from floor plan directly.I need convert objects to blocks option to be active and i can only achieve it when i export directly from floor plan not from layo...
Virtuoz by Participant
  • 336 Views
  • 3 replies
  • 0 likes
Attached XREF won't show up on worksheets.
Any time I try to import the map through XREF on worksheet, nothing shows up after the process. The page is blank. But when I open a new file and attach the xref map, there is no issue at all. I don't understand where the problem is. Is it the templa...
mvkpamas by Participant
  • 274 Views
  • 1 replies
  • 0 likes
