MEP modeler - P-trap
How to model a P-trap? Is there somewhere a P-trap smart object???
I am having trouble translating my archicad files to .dwg properly. The text in my archicad file is wrapped but then when I save it as .dwg and open the .dwg file the text is in a single line. This is happening in text blocks and zone stamps, but lab...
Hi Everyone, I am an absolute beginner with ArchiCAD. I have been trying to save as an ArchiCAD model as an IFC file but I couldn't manage to do so neither export an IFC file nor import an IFC file generated from Revit, and I need it urgently as I ne...
Hey guys, I'm faceing a problem when exporting my file to c4d, I set my units in both archicad and C4D in cm, the scale factor in the cinema 4D settings in archicad is 1 so everything seems right but still getting false scale in cinema 4d. any help ?...
Hi I have just started to have this message / report open up on every file - can anyone help? Thanks, C:\Program Files\GRAPHISOFT\ArchiCAD 18\ArchiCAD.exe Unused in temporary folder : 778843.8 MB File not found in the library while operating on file ...
I want to create a window/door schedule that has the opening width and opening height in individual columns in measured units (feet-inches). For example, in the Archicad 21 Commercial Template, these are labeled as follows and noted in blue typeface:...
Hi Guys, For the life of me I cannot find a way to make a keynote. I want to make a label that allows me to type in the content and pick a shape for it. That way I could differentiate between doors and window etc in the elevations. It seems so basic,...
Anybody can suggest a way of bringing in the vectorial data in a PDF (lines, perhaps fills, perhaps text) so that it is editable in Archicad? I am trying an online converter to DWG with so-so results.
I am trying to import a Google Earth terrain model into Archicad thru Sketchup. I was able to do this just this past winter. Sketchup has since changed it's ways and requires one to own Sketchup PRO ($695.00) to have this functionality. Are there oth...
Hy.I have a new dell laptop.I have a 3840x2160 resolution.I install the archicad and the black cursor is very very small!!!Can you help me?
User | Count |
17 | |
6 | |
6 | |
5 | |
4 |
