MEP Modeler 21
Is there anything changed in MEP Modeler version 21 from 20? Do they charge for an upgrade?
I've read the following: https://helpcenter.graphisoft.com/tips/collaboration/dwg/import-dxfdwg-files-to-archicad-2/ I'd just like to check that there aren't any pitfalls similar to in Revit. For Revit, linking a DWG was the best option wherever poss...
Hi there, I have drawn a cadimage window unit - that is a combination of windows and doors - I am not able to put glazing bars on the doors? it will only let me put the glazing bars on the windows. anyone got a solution to this? cheers
Hello, A hardware failure caused our very old Mac server (kept for v16 BIM compatibility) to become inoperable. Restoration of that system is not feasible. We have a backup of the BIM server data directory with all the projects. I installed the BIM s...
I am working on Appliance and Plumbing Schedules. I would like to list the objects by the room zone that they are in. In my model I have zones for each room, but I also have some overall zones in the same areas on hidden layers. My schedule is not se...
In the previous versions of Archicad, the Full Element ID of objects was able to be adjusted within a schedule that referenced it (as long as the layer was on). In version 21, it seems that is no longer the case and that the IDs can now only be adjus...
Hi everybody, I am facing a problem when trying to generate door schedule with wall in 2D symbol. Is there any option to add a penetrated wall on a certain distance on each side of the frame? I guess that is pretty useful feature which i cannot find....
Hello, Where can I find the "element ID manager" FILE in the computer installation ? Thanks
Hi, I was wondering if there is a way or an option to auto adjust all schedule cell sizes to fit to the content? Every time I modify a schedule enough I will need to go and double click on the black lines in the ruler to make it fit to the content of...
Greetings. I have a few dwg translators for different consultants in AC19 that I would like to import into AC21. Other than copying the xml file from the User's path or rebuilding the translators from scratch in 21, is there a way to export the xml f...
User | Count |
18 | |
6 | |
5 | |
5 | |
4 |
