Custom pipe profile in MEP Modeler
Hi. Is it possible to create a custom pipe profile for MEP Modeler? What I need is to have a "box" that contains pipes and insulation. Square "duct" containing foam and one or more round pipes.
I am having various issues when importing a Consultant's IFC model. He has installed the Graphisoft plug-in for Revit but it is bringing in a very recent version of our Building Model as well as Storey Levels that are not being used and finally their...
Hi! Today we noticed that our sheet index is sorting the sheets in a strange way, but here is the kicker: sorting is turned off in the index settings! (Please see the attached screenshots.) I have no idea what criteria it is using to sort the sheets ...
Hi! I'm working on a project template for AC20. And i'm noticing some differences to AC 19. I have created some favorites like doors, walls etc. For example: I have a door on favorites, with measurements 910x2100, ID D9a. When i have that door select...
The export from Archicad (mac osx) to 3DS MAX is pitiful! Export in .3ds format: Textures: - name reduced to 8 characters - exported to bmp (24 bits, not recognized by Max> 32 bits) - UV mapping not conforming to Archicad mapping Materials : - name r...
I am getting to know the workflow for ArchiCAD and I am wondering what the best way is to set up door and window schedules? I was very excited initially about the parametric aspects of ArchiCAD and BIM modeling. I thought it was very cool how you cou...
In ArchiCAD 20 the Find & Select is a little different, making it particularly useful to create one's own Criteria Sets that one can use over and over rather than having to manually click through all the options every time. It appears as though we ca...
Hi, How can I calculate the total area of units in a multi-storey development? I would like to show the following criteria in a schedule: Unit Type / Total Area / Ground Floor Area / 1st Floor Area I had the same problem with total unit areas, adding...
I'm not a current Archicad user but was in the distant past.... I've got some files dating from 1999/2000 - Archicad version 6. They are too old to open in the current demo version of Archicad. I've found that you can download old (versions 9 and 10)...
Hi guys! Has anyone of you worked with CFD simulation and ArchiCAD? What CFD software did you use? Cheers!
User | Count |
18 | |
6 | |
6 | |
5 | |
4 |
