IFC rule with boolean resault
Is it possible to make a rule for a wall that says, if my wall is on a specific layer then my custom (boolean) parameter says "true" and if not it says "false"?? If so, please tell my how. Thank you!
Is it possible to create a xref using a pln file and not a dwg? If so can someone explain how it works.
first time poster: It is great that there is a capability to export zone categories as a classification reference to ifc. But proper coherence would propose that you could import that property in the same way. Best regards
Export to AutoCAD Explodes everything no matter what translation settings I use. Even the dimensions are reduced to a series of independent lines and number. In summary, 1, I have created a project with layouts containing the GA's etc. 2, I go to the...
Hi It seems that the Wall Accessories add-on is not released so far for ArchiCad 20. I am wondering if this will be done in the future and when? Or if there are other methods for modeling curtain walls, like following properties of specific manufactu...
Hi, I'm having an issue in AC19 where the project fails to export a 3DS - it just sits there spinning. It happily generates OBJ or DXF files, but I need 3DS for my purposes. The folder shows some empty scratch files that get created, but no real idea...
Are any of the Kiwi users here using the bracing tool? Have you been able to use it for subfloor bracing lately? I used to use it up until last year some time, but it has had some issues which supposedly have now been fixed, but I still cannot get it...
Is there a way of multiplying area and number of windows within the schedule in Archicad 20?
There has been a change of project architects on a project I have been working on. I have been using ArchiCAD 20 and the new contracted architect is using ArchiCAD 17. Any thoughts on the best way to transfer the project to him, so that he can contin...
How do i figure out what centres my purlins are at because they are not spacing at the centres that i filled out in the settings
User | Count |
17 | |
6 | |
6 | |
5 | |
4 |
