Collaborate forum
Forum Posts
how many cores to calculate schedules
As per object, how many cores are used by AC to calculate schedule? I noted 2 cores are in use during schedule updating. Is it possible to use all the cores to speed up the process? Thanks
alemanda by Participant
  • 972 Views
  • 0 replies
  • 0 likes
Export to autocad (dwg) - specific queries
Has anyone (successfully) addressed the following in the process of exporting archicad drawings to autocad: 1) Exporting colours as "BYLAYER" so that when opened in autocad, colours adopt template layer colours (which is office standard protocol). Th...
Anonymous by Not applicable
  • 1050 Views
  • 0 replies
  • 0 likes
unable to delete BIM Library
Hi, we had some problems with our server, tried uploading the ArchiCad 18 library and something went wrong. Now I can see the library when I go to Manage Bim Server libraries but i'm unable to delete it. I think this is the reason we can't upload any...
  • 1342 Views
  • 0 replies
  • 0 likes
Office ArchiCAD structure
Hello, our office it's ArchiCad preferences aren't the most optimized/structured. So i've assigned myself into creating a new office template/custom library/layout setup/structure etc. Before I start doing this I wanted to ask you guys for your input...
  • 10512 Views
  • 9 replies
  • 0 likes
apple - yosemite - multiple spaces, windows, displays
has anybody found a app or workaround, THAT WORKS to maintain your windows across multiple spaces, when switching between 1 or 2 monitors. it's 2016 and im trying to get organised. my current setup (at work) is 1 mbp and a 27 inch ext display, usuall...
  • 2023 Views
  • 2 replies
  • 0 likes
Suffix m2
Hi! The suffix "m2" in Archicad Schedule is a big problem for me. I'm trying to create a master Excel spreadsheet composed by several Archicad schedules and the field "grand total" with the suffix "m2" is not a valid number in excel. Is there a way t...
  • 1733 Views
  • 2 replies
  • 0 likes
Z-values of a text file into a mesh?
Hi! I have a text file(* which has thousands of Z-values separated by a space. I wonder is it possible to get them into a MESH using GDL script? I’ve been able to read the values from text file using Text I/O add-on, and even put them into parameter ...
  • 7137 Views
  • 11 replies
  • 0 likes
