Scheme Settings - Calculated Field
Can you add a field to a Scheme Schedule that is a multiple or derived for a calculation of a fixed number or even a calculation of two other fields?
has anybody found a app or workaround, THAT WORKS to maintain your windows across multiple spaces, when switching between 1 or 2 monitors. it's 2016 and im trying to get organised. my current setup (at work) is 1 mbp and a 27 inch ext display, usuall...
Hi! The suffix "m2" in Archicad Schedule is a big problem for me. I'm trying to create a master Excel spreadsheet composed by several Archicad schedules and the field "grand total" with the suffix "m2" is not a valid number in excel. Is there a way t...
Hi! I have a text file(* which has thousands of Z-values separated by a space. I wonder is it possible to get them into a MESH using GDL script? I’ve been able to read the values from text file using Text I/O add-on, and even put them into parameter ...
Okay so I came across this tool that's been developed by Graphisoft Australia as a localised tool, and I have to say it looks Amazing as a freeform multipanel window and door desiginer. http://graphisoft.com.au/windows-and-door-tools/ My question as ...
The INT version was available for a while. Now the German, Italian, Japanese and Chinese versions have also become available. To download them visit: http://www.graphisoft.com/downloads/interoperability.html
Hi, when import dwg files which contains attributes, the attributes are not translated properly in Archicad. Instead of the attribute block I get a straight line. This is happening either in "place external drawing" or in "XREF import". The attribute...
Hi, when I try to import a 1:100 scaled dwg file as an external drawing the imported text and labels are anlarged by double (depending of the autocad file scale the enlargement may be bigger). To achieve the same text height I have to either change m...
Can anyone recommend a tool for creating Road ways? I have used ArchiTerra in the past, and besides at the time not being able to super elevate one side of the road way in respect to the other, I had success with producing sloped and curved driveways...
Working in the door schedule - some of the panes are frozen - the entire of panes within one door. I can't use the door locator to identify the location of the door to delete. I can't modify the designation to 00 (my designation for empty doors). Ple...
User | Count |
17 | |
6 | |
6 | |
5 | |
4 |
