Door/Window List dimensions
Im having some issues working out how to change the dimensions from level (elevation) dimensions to linear dimensions. Does anyone have any hints? Im working in Archicad 18
HI everyone, I have a problem with IFC in complex walls! How can I create a complex wall with different IFC in each component? Thank you in advance!
Goodmorning forum, I think I have a rather silly problem, but it bugs me. I created some simple schedules and everything is running smoothly except the order of the numbers, as you can see in the attached picture they go from 1 to 10-19 and then to 2...
I am creating some wall schedules to show some simple length and area values for a builder client. I have got them showing the column totals I want but noticed an odd thing. If I create a new wall it shows up in the schedule on a new line but if I du...
I have an old project done back in early 2011 that is only saved on our network in .BIMProject format. Currently the office is on Archicad18 so logged into the server and tried to import the project into the server but the only message I am getting i...
I am working on a project with a lot of hotlinks. We use zones for our area calculations per floor and I have placed them in the mods. We schedule the Calculated Area per Level in our base file but since I have 10 of a single type of unit it schedule...
http://helpcenter.graphisoft.com/technotes/bimcloud-and-bim-server/setting-up-bimcloud-and-bim-server/bim-server-and-bimcloud-backup-guides/
Is it possible to get an email notification when someone sends me a teamwork message? Also, is it possible for me to send a teamwork message that will be forwarded onto one of my teammates email address stored in their teamwork profile?
I've tried to import a Point Cloud into ArchiCAD in e57 file format but no luck. The error message says that the file is invalid and cannot be imported. Has this file format any limitation maybe?
Trying to figure out how to get teamwork working for my sometimes remote worker employee... Here is the setup... My Macbook Pro laptop running ArchiCad 19 which is also the Teamwork Server. The employees Macbook Pro Laptop running Archicad 19 which i...
User | Count |
6 | |
6 | |
5 | |
4 | |
4 |
