Collaborate forum
Forum Posts
windows and doors not showing zone on schedule
Hi I have a problem setting up a window and door schedule for a building that has 3 zones. All the doors and windows show on the schedule, but their zone location will only show for some of the windows and none of the doors. its a problem with all th...
Anonymous by Not applicable
  • 4624 Views
  • 1 replies
  • 0 likes
Curtainwall schedule - 3d view? elevation?
Hello, We are doing our first job in ArchiCAD and I am running into an issue with scheduling a couple of curtain walls. What we like to do to aside from an actual door schedule (spreadsheet type), we like to create a graphic type "Opening Schedule" w...
  • 16328 Views
  • 15 replies
  • 0 likes
schedule layout
Hi I have several different schedules created for elements, walls, floors, openings etc Is there a way to quickly transfer the layout from one to another, so that they have the same layout, font size etc. merci Strawbale
  • 3659 Views
  • 6 replies
  • 0 likes
Pdf Publisher
Hi, I am working in Teamwork ArchiCAD 15, and would like to use publisher to create pdfs. I have done this very easily in non teamwork files. I can create a new folder but it does not let me add to an existing folder. I have tried reserving the whole...
  • 8759 Views
  • 10 replies
  • 0 likes
What is POR in the Zone Identifier 2 15?
I am using the Zone Identifier 2 15 stamp, and have two questions... 1. When i use the Sum of Spaces Schedule a column shows up that is called POR. I can't figure out what this is, and when i input a value in the column I don't see it show up in the ...
Bill by Newcomer
  • 1496 Views
  • 0 replies
  • 0 likes
schedule scroll bar gone
I have always had trouble getting the bottom scroll bar in the window schedule to show up. Now it has disappeared entirely, and at the same time that it disappeared, the entire schedule got smaller, as if I had "zoomed out". So how does one "zoom" in...
Team work crash
Need a solution, my partner is in another city and when he stays logged to the server over night his computer says he is on line but he cannot send and receive. Then if he logs off he cannot get back on that drawing ever. There has to be a file writt...
  • 2248 Views
  • 2 replies
  • 0 likes
