Collaborate forum
Forum Posts
MEP Modeler library problem
Has anyone been using MEP Modeler with TW??? I just installed it today, and its working fine with solo projects, but i cannot get it to work with TW... Specifically, i have uploaded the MEP library to the BIM Server and added it to the TW project, bu...
Revit Server - Bim Server?
I understand Revit now has (August of 2010) put out a "bim server" type functionality in it's software. Has anyone had the pleasure of "testing" it out to see how it compares to Archicad's BIM server??
rob2218 by Contributor
  • 3535 Views
  • 3 replies
  • 0 likes
How many BIM servers?
We are an office with around 30 architects using Archicad on Mac and have been working with Teamwork under AC13 for the last few months. Not all of our projects have been converted to AC13, nor have seen the neccesity of Teamwork, so the BIM server o...
Anonymous by Not applicable
  • 4077 Views
  • 5 replies
  • 0 likes
AC14 compatible GDL Adapter
The GDL Adapter has been updated for AC14. It also works with AutoCAD 2011: http://www.graphisoft.com/products/archicad/parametric_objects/products/adapter.html The download page: http://www.graphisoft.com/products/archicad/parametric_objects/downloa...
Help!How to show the zone name of the wall inside it?
I palce the wall around the zone. The zone name of the wall inside the wall schedule list is OK. When the walls is placed inside the zone, the zone name of the wall inside the wall schedule disappear. I tried to change " relation to zones "/ "Listing...
  • 2214 Views
  • 1 replies
  • 0 likes
Help! Zone name of wall disappear!
I make a complex wall as the ceiling skirting. I hope the wall schedule could clearly show this ceiling skiring's properties such as width, height and zone name. The zone name of the wall could clearly be shown in the schedule ( Figure 01), once I ma...
  • 1990 Views
  • 2 replies
  • 0 likes
Interactive scheduling
Please can someone assist me? I'm using interactive schedules for my door schedules. I've used standard ArchiCAD doors & the standard ArchiCAD scheduling tool. I used the "3D Front View" to generate an elevation of the doors. I used the "automatic di...
  • 1841 Views
  • 0 replies
  • 0 likes
What 's the rule for judging the wall's Zone Name
The wall is connected with "Zone F" and "Zone G". The reference line is adjacent to the Zone F. I want to figure out what is the rule for the "Zone name" shown in the Wall schedule. As I will calculate the surface area of several walls around one zon...
  • 2080 Views
  • 1 replies
  • 0 likes
Incorrect calculated area of Zone Schedule
I set the Zone deduction(Figure 01), column relatoinship with zone(Figure 02) already. As you could see the Figure 03, the area difference would be around 2 sq.m. It's obvious the calculated area of Shop G(Figure 04). However other areas is correct. ...
  • 4126 Views
  • 5 replies
  • 0 likes
ArchiCAD Master Template Use
Hi, Have any experienced users tried 'ArchiCAD Master Template'? If so how have you found it to perform and was it difficult to get your own custom defaults implemented? What are its Pros and Cons for its USE? Shoul I Try it?
  • 2719 Views
  • 1 replies
  • 0 likes
