REM/design, ArchiCAD, and .ifcxml
Has anyone dealt with exporting data from ArchiCAD to REM/design? I'm trying to figure out if .ifcxml has been successful. Or if there's a better program to use to do energy analysis.
been struggling with remote connection for ~18 months now. AC13 crashed repeatedly without a bug reporter upon opening the .twlink file. AC14 at least attempts to connect and gives me attached diagnostic help. I've confirmed the 4 ports required to b...
Hello ArchiCAD friends I have a problem which would be nice to get under control since I know there must be a solution for such a simple matter. My problem is when importing a 2D element from a Archicad group, (eg., a toilet consisting of several lin...
I don't know whats happening, but with build 3269 the BIM server is acting really buggy. Every time (and i mean every single time) i open the BIM Server Manager and then on a specific project's settings, the program crashes! And i cannot send a bug r...
When trying to open a Teamwork project, I get "your client is not compatible with the selected server Server version 14.0.3004, Client version 14.0.3269." I have tried uninstalling & reinstalling BIM Server & Manager, but I think a Hot fix has messed...
Is it posible? I can combine objective with object slicer to make floor plan with cut and proyections? Many thanks.
Is it possible to use ArchiCAD as editor of dwg files? Sometimes I need to edit dwg files (only 2D, hatches, layouts, blocks) and do not want to buy autocad LT. Any tips or converter templates to keep source dwg after saving intacted?
Well, after trying to finally settle down the IFC issues, something else came up we noticed. Apparently, there were some wall fills (or any fill for that matter) that were in one hotlink TW file that weren't in another one. When one file was being li...
Is there a 3ds in addon for archicad version 14? i have found it only for version 10... Please help me, and thanks
One thing i never understood with AC is why things that worked on previous versions, get trashed in newer ones... For example: Greek language text in zone list in AC 13 appears like this: and in AC 14 appears like this: appart from the obvius non-uni...
User | Count |
5 | |
4 | |
3 | |
3 | |
2 |
