Collaborate forum
Forum Posts
Cadimage!!
I just downloaded ArchiCAD 14 and I was hoping to take Cadimage with it from having it on 13. Never used Cadimage but heard good things, wanted to try it with 14. Where can I download it for 14? For some reason I can only seem to find objects for it,...
Anonymous by Not applicable
  • 2783 Views
  • 2 replies
  • 0 likes
Library Ojbects exploding in DWG conversion
Hello All, Im having this little problem with my library parts when converting it into DWG's. For some reason, my toilets keeps exploding in the dwg file. Its not every toilet, but every other toilet. I've check the translator settings over and over ...
  • 1628 Views
  • 1 replies
  • 0 likes
Problems with Cadimage StairBuilder 13
hi, I´ve got a problem using Stairbuilder from Cadimage for AC13. After build a stair and put some railings I receive this error message: "file not found at line 250 in the 3D script of file CT railing.gsm", and I cannot see the 3D render window. Any...
  • 2134 Views
  • 2 replies
  • 0 likes
BIM Server 14 Library issue
OK, We have finally got around to updating to v14, but are having some strange issues getting BIM Server Libraries to load. On Client Machines: In AC14, I cannot get BIM Server Libraries to load... they show in the list, but are listed as "offline". ...
  • 40980 Views
  • 55 replies
  • 0 likes
Questions about linking Properties to Criteria
I have a set of Criteria set with AC 13, now that I open an AC 14 file, for some reason i do not see all of the Criteria, but only some of them... Why? Is there a way to import criteria? Where are criteria saved? Individually in the file, or centrall...
preparation for the calculation of
I started studying computing gear and got into the problem. When you find "ArchiCAD 13 Calculation Guide" and the Guide can not find the necessary tools Edit Database New Properties Edit Properties Last Selection's Properties Link Properties to Crite...
  • 2359 Views
  • 3 replies
  • 0 likes
ArchiCAD, WibuKey and the Snow Leopard firewall
Has anyone managed to get ArchiCAD to work with a WkLAN Server when the Snow Leopard Application Firewall is running? Simply adding ArchiCAD to the allowed list doesn't work. I've also tried allowing port 22347 in my ipfw list, but that doesn't work ...
  • 4354 Views
  • 4 replies
  • 0 likes
Couldn't access BIM server through internet
Guys, i need help on login in BIM server through internet issue. i had setup a BIM server for my company internal used and everything is perfectly fine but when i try to access the server through internet, i can see the server appear but the server c...
  • 1368 Views
  • 0 replies
  • 0 likes
Can't delete a library from the BIM server
Hi there, I hoping this error has happened before. I am having trouble updating a BIM server library. I selected delete and nothing happens?? I am using 'manage bim server libraries'. I was able to delete other libraries on the BIM server, just not t...
  • 1479 Views
  • 0 replies
  • 0 likes
