Collaborate forum
Forum Posts
TW2 Forces close of file
AC13 running current hotfix, on All MAC system running snow leopard. Two files both on BIM server. one has the project and the other has the layouts. Must have both files open or it will not update. Then error message of unsent changes from the sourc...
Anonymous by Not applicable
  • 1658 Views
  • 1 replies
  • 0 likes
Sharing attribute files
Is there any reason why we cannot have a sub forum specifically for sharing attribute files, pen sets, layouts etc? I think this would benefit an enormous amount of people who don't always have the courage to start personalizing their Archicad setup ...
  • 5042 Views
  • 4 replies
  • 0 likes
Issues (DNS??) running AC13 TW2
Hi, I am running into an issue where the AC13 TW2 module not maintaining clients 'online'. When clients try to reconnect (deselecting 'Working Offline' in the TeamWork menu) the client makes an attempt, is connected for a few seconds and then shows t...
  • 1650 Views
  • 1 replies
  • 0 likes
DWG export hangs AC14
"Of course I can give you DWG" - I say happily to my consultants! It will be over in a jiffy!. 2 hours and 2 freezes later and I am yet to get a result. Publisher says it is saving.... but never finishes. Any subsequent clicking causes windows to rep...
  • 6695 Views
  • 8 replies
  • 0 likes
DOOR SCHEDULE
Attached is my door schedule...sort of. Want to list doors alphabetically. Can anyone tell me how to get the schedule to list alphabetically, rather than the mess I have now. Never had this problem before.
  • 2948 Views
  • 3 replies
  • 0 likes
Tip: restoring Deleted elements
Just a tip to those using TW2. Today a user came up at 5:00 with a big problem. A large portion of the project was missing. After a little investigating I discovered the user had accidentally deleted the missing elements. They were in his work space,...
  • 1268 Views
  • 0 replies
  • 0 likes
ArchiTerra Road Problem
Hi, I am using ArchiTerra 3 with ArchiCad 12. I have built my site using a DXF file and everything was fine, up to the point when I started putting in the road. The problem is; when the road is below grade at some points, the road does not cut into t...
  • 2414 Views
  • 1 replies
  • 0 likes
F Y I - Teamwork 14 - Open Deleted Projects
I thought I would report on an issue we had and the solution in the event anybody else has this issue. We had a teamwork project that had to get re-teamworked. The original file was deleted from the bimserver after the new file was created. The new f...
BIM Server connections over VPN
I'm having issues connecting to BIM Server 14 over our VPN. We're running two dedicated W7 Pro 64bit machines in two offices, each on their own network. We have a dedicated VPN in place which allows us to VoIP our phones and I can remote access all t...
  • 2039 Views
  • 0 replies
  • 0 likes
Labels
