Collaborate forum
Forum Posts
from sketch uo to archicad 13 in a mac
hi im new using archicad, and i need to turn in a school project next week and im tryiting to use some objetcs from sketch up, but i don;t how to import them to archicad, i have a macbbok with archicad 13 and sketch up 7 can somebody hel me, i need t...
Anonymous by Not applicable
  • 2206 Views
  • 2 replies
  • 0 likes
Remove colors from window/door schedules
How does one remove the material "colour" from doors and windows in the Interactive schedule? and how does the same one change the site and format of the door number? It must be simple I'm sure but I have spent much time looking.
  • 13884 Views
  • 6 replies
  • 0 likes
importing archiCAD files into vectorworks
howdy we have a project that was done exclusively in 2D our client is now asking for vectorworks files is that something we can provide... or do we need to export to dwg/ dxf we are currently on archiCAD v11... but i have colleagues who are using v12...
  • 5823 Views
  • 6 replies
  • 0 likes
BIM Server Mgr - what version is running?
Am I missing something or is there no obvious way to check what version of BIM Server Manager is running? There are very few Mac applications that don't have an "About" window...I don't know why BSM needs to be one of them.
IFC IMPORT
Hello… I have just imported IFC data in Archicad…looks good...but from the plan view it shows this new model as if it was in wireframe view…it shows all the lines of this model…but I wish to see only the counter lines…exactly like Archicad would norm...
  • 2729 Views
  • 4 replies
  • 0 likes
Interactive Schedule Frustration!!! - Part 2
Can anyone explain to me, or point me towards a clear description, of what determines the 3d 'front' view of a door/window in a schedule, as opposed to the 'back' view . Rant follows if you need more info: I was of the opinion that when you placed th...
  • 20882 Views
  • 10 replies
  • 0 likes
gdl objects information in a Template
is it possible to save the configuration of every door or windows or gdl objects in a template? so that whenever i start a project and i insert a door for example.. it's symbol would appear with the pens linetypes and even the scale that i assigned t...
  • 4812 Views
  • 3 replies
  • 0 likes
Schedules and grouping/summing similar items
Can anyone tell me how to get a door/window Schedule to group doorS and/or windows with similar IDs? For example, how do I get doors labeled S1(of which there are several) to show up in only 1 row with the correct quantity indicated next to it (as op...
  • 7496 Views
  • 8 replies
  • 0 likes
Slab schedule
I am using AC for plywood-furniture design, and have trouble with slab schedule, I can't find a way to list dimension of the slab(like walls), only surface, thickness and volume are available... Any ideas how to list dimensions of the slabs?
  • 2480 Views
  • 2 replies
  • 0 likes
detail library
Hi I am just setting up archicad in the office. What is the best way to go about setting up a detail library. Just standard eaves etc. I would like to be able to use them as "detail templates" while I rebuild the library, and store them separately to...
  • 30836 Views
  • 27 replies
  • 0 likes
