Collaborate forum
Forum Posts
Interactive Schedule in Teamwork
I have a window in a hotlink that I have listed in an interactive schedule. I can annotate, but cannot update/revise schedule fields as I cannot reserve the window. How do I update/revised schedule fields of a hotlinked window?
Anonymous by Not applicable
  • 1705 Views
  • 1 replies
  • 0 likes
Problem with referenced key code in database.
Hi, everyone! I'm trying to master the difficult art of quantity survey with AC. I have purchased the book "Archicad from CAD to Quantity Survey" by Eric Wilk, and i must say it is really helpful. I have created my own Components, Descriptors and Key...
Portable TW2 workaround?
Ok Brainstrust I have an idea. I'm pretty sure it won't work but would like to know why not! ':wink:' As a work-around to re-building the model and all BIM server libraries on my pc/mac at home which when using a VPN over here (down undah) can take w...
  • 5278 Views
  • 8 replies
  • 0 likes
camera movement once exported to artlantis
hi basically im rendering using the sketch engine and after this i want to keep the exact view i have from archicad and put it into artlantis. after i do this i find the camera has moved and is out of place. the only reason i export it into artlantis...
  • 1690 Views
  • 1 replies
  • 0 likes
Attaching an XREF from autocad?
using AC12. trying to "External reference" attach a DWG file from Acad. thing is....it comes in locked which fine I can unlock "ALL" the layers. but....I can't seem to "MOVE" the linework? what gives? whats the appropriate setting I need to attach an...
rob2218 by Booster
  • 20150 Views
  • 11 replies
  • 0 likes
Zones and interactive schedule
I am wroking on calcuating occupancy of buildings using the zones and the IBC loading factor. The zone stamp is doing all the calculation, and displays it on the plan. This all works great; when the Update Zones command is run, the zones update and t...
  • 2042 Views
  • 1 replies
  • 0 likes
Exporting to sketchup is not coming...
I can import files from sketchup to AC13 but not able to save files in sketchup format...i used get that option before and i did save some models but it suddenly started like i cant save...the Google WH skp file and GE model options are not availaabl...
  • 1436 Views
  • 1 replies
  • 0 likes
