Collaborate forum
Forum Posts
Sketchup Add-on discontinued !
i'm really sorry to have to post this, but as it is also an annoucement that should have been made "separately" i'll do it; cause it is not even in the sketchup add-on webpage. as i've noticed here , the sketchup addon that translate sketchup surface...
TMA_80 by Booster
  • 1682 Views
  • 0 replies
  • 0 likes
Cool !
Hi! Here is a little plugin for the conceptual modeling tool for Revit 2010 ; don't know if i'll ever have to use it ... At least we know what is happening on the other side . http://buildz.blogspot.com/2009/12/api-yi-yi-bitmap-to-panel-plugin.html
TMA_80 by Booster
  • 1472 Views
  • 0 replies
  • 0 likes
ArchiCAD-Tekla Structures Interoperability Guide
Here is another PDF document about ArchiCAD-Tekla Structures Interoperability: http://download.graphisoft.com/ftp/pdf/InteroperabilityAC15.pdf (Note: the original link was not available anymore, hence the other posts in this thread, now the correct l...
Rough Opening Header Heights
I'm trying (very hard) to show the rough opening header height in my Door/Window Schedules. Seems there's no option for Header heights, only Sill heights. All the available schedule parameters will show the height of the unit, and not the rough openi...
Anonymous by Not applicable
  • 4202 Views
  • 4 replies
  • 0 likes
documentation of door window schedule!!!!!!!!
while documenting , in schedules , its easy to get the listing & 3d view / elevation of the doors / windows, but how to document the detailed dimensions viz: transom level,thickness of frame, width ofthe divisions/panels????/
  • 3885 Views
  • 5 replies
  • 0 likes
door not showing in plan
Does anyone know why a door (d&w builder) does not show up in plan, but does in elevation? Just a dot and the opening appear. This plan was started in windows on a pc, but I am now using a mac. The door appears in plan on the pc. This is strange. Eve...
Most compatible conflict checking program with ArchiCAD
I've just started some research in searching for which "conflict-checking" program or add-on would be most compatible with ArchiCAD? I've noticed that Solibri provides a conflict checking program for the IFC models in addition to its Solibri Model Vi...
  • 29114 Views
  • 28 replies
  • 0 likes
Improved font smoothing for Snow Leopard
For Snow Leopard users who use monitors not manufactured by Apple... I'd been noticing some eye strain since upgrading to SL but didn't realize what it was. This MacWorld tip explains it - they changed the font smoothing. I just used the setting in t...
