Collaborate forum
Forum Posts
Link multiple model views to a single worksheet
Hello and happy holydays to everyone, I have a question regarding worksheets. There are situations in which our collaborators require DWG files containing all plans, sections, façades and details. The problem is that since we derive this data from ou...
Anonymous by Not applicable
  • 416 Views
  • 4 replies
  • 0 likes
ArchiCAD 24 and Light Schedule Symbol
I'm trying to create a schedule for lighting. I create the schedule, It looks correct in the schedule viewer, the 2D symbol does not show when I put the schedule on a sheet. What am I missing? See the below sequence of screen shots. This is the Sched...
  • 709 Views
  • 5 replies
  • 0 likes
Archicad Interactive Schedules from Worksheet
Through a bit of searching I cannot find any similar posts or any reference in the Graphisoft help center. Can Interactive Schedules be generated from 'objects' on worksheets? 'Objects' can be placed on a worksheet and auto labelled. Is there a reaso...
  • 575 Views
  • 4 replies
  • 0 likes
Archicad23 and COBie
Hey everyone, I just chck the official website of Graphisoft and only find AC22 with COBIe template, does this template can use in AC23 as well?
Resolved! Detach XREF from XREF Manager
Hello, I currently have six files located in my XREF manager that I am unable to detach. I select all six files, click "detach", and then click "remove XREF's attributes" in the following dialogue box. Everything appears correct in the log, but after...
  • 1121 Views
  • 7 replies
  • 0 likes
Navisworks Freedom for ArchiCAD 24
Navisworks add-on makes it possible to save a 3d ArchiCAD model as a *.nwc file which can be viewed in Navisworks, but apparently not as a *.nwd that so it can be seen with the free Navisworks Freedom viewer. So is seems that we would still need Navi...
Property Manager_create new properties
[list=]I would like to create a new property group listing the name of occupants and the rooms they occupy. [list=]I have created the group named coordination --> inside this I will have the new property called occupants. HOW DO I ASSIGN A PERSON TO ...
  • 1167 Views
  • 11 replies
  • 0 likes
