Collaborate forum
Forum Posts
ArchiCAD Template and Library - free download
Hi there!I have decided to give a link to the template and library I have developed for projects I've been working on.Feel free to download and review. Any comments are welcomed.The Template was developed for UK. I used British standards: BS 8541-2:2...
Using ArchiCAD 20 to import survey data
I'm trying to figure out the best approach to get 3D data from a surveyor into ArchiCAD 20. DWGs, DXFs, Sketchup files, and Google Earth files have all been tried. It appears that nothing is working. I've tried importing external drawings, using the ...
Anonymous by Not applicable
  • 505 Views
  • 1 replies
  • 0 likes
IFC Library Objects only show on the lowest storey
IFC Library Objects only show on the lowest storey of the Model despite being linked to a higher storey. In the attached screenshots you can see the settings for these objects so they should not be visible on the -3 Datum storey but they are. The onl...
Question about compatibility with other geometries
ArchiCAD has quite good imports from another 3D packages. But all of them are coming as library part objects (tool that has chair icon). Later you can explode them (if you want) into editable morph tool - that is some sort of native 3D mesh. If talk ...
DXF-DWG translation problems
Hello, I'm struggling with dwg export to (mainly) Autocad. I'm trying to export correct units and linetype scales, but unfortunately I can't get them both working together at the same time. My assumptions (Archicad): Working scale: 1:100 Drawing scal...
  • 1662 Views
  • 10 replies
  • 0 likes
DWG export and Transmittal managing problems AC24
I feel like this is a huge problem that it should be addresed soon, and it has taken me too many hours to try to solve, with no success. AC24 has a lot of issues when exporting to DWG, issues AC22 didn't have (the version i've been working before) Pl...
CaticonC by Contributor
  • 1118 Views
  • 7 replies
  • 0 likes
