Collaborate forum
Forum Posts
QUESTION - CHANGING SCHEDULES GLOBALLY
Hello everyone! Is there any way to change 100 schedules with one global option? For example the font type and size is wrong in all of them - should I go to every single schedules to change these settings? It is very time consuming. Thank you in adva...
ArchiCAD vs Revit origin + north forIFC coordination
Hi All, i'm working on a project on archicad , and i'll coordinate with a revit user, so the first thing is to correctly set the project location, ArchiCAD and revit location systemps are diferent, so i searched on the net, and i found this web page ...
FreeMVD - BIM Roundtripping - Extrusions
Anyone know ArchiCAD, IFC, & Github pretty well? If so, any interest to roundtrip the file circled below? And then push the resultant .PLN and .IFC files? https://github.com/OpeningDesign/FreeMVD_WorkFlow/tree/master/Specifications_Test_Files/Extrusi...
Empty DWG when opening with AC23
Hello, I have a problem with opening any dwg in AC23 (commercial version). They are totally empty. But when I open the same file with AC22 (edu version) it is all right. In this way I am not able to work with the AC23 version Does anyone know a solut...
Component Area Errors in Schedules
I've encountered this problem, when i try to calculate the area of a certain skin through the projected component/skin area listing parameter, if the element is cut by another element through SEO in a certain way (still haven't figured what's the con...
Zone Top area
Hello, does ArchiCAD have the ability to show Zone top area (when it's been cut/cropped by a roof)? Regards, P.
adzik by Newcomer
  • 490 Views
  • 4 replies
  • 0 likes
