Export Translator Settings
I want to share a DWG export translator with a colleague. Can't figure out how to export the settings. Note this is not the IFC translator.
I receive lots of IFC files from structural engineers who use different software which I should import to my architectural models. Sometimes the classifications of the elements modeled are correct and sometimes not. Sometimes they have correct layers...
Is there a way to get the total quantity of zones in certain zone category and use that integer in an expression based property? What I am after is calculating the average (arithmetic mean) area of zones of certain type, by dividing the total area wi...
Dear All, As you are most probably aware, with Archicad 24 we introduced the Structural Analytical Model Exchange workflow. Now as some time has gone by and you had a chance to try it out, I would be really interested to hear your feedback. Please le...
How to make element ID's, specifically Windows and Doors to be fixed number? I'm trying to create a catalogue of windows that correspond to real products and each window has unique product number, which I want to assign as ID within Archicad. The pro...
Hi guys, Does anyone know, what it is and how end user can benefit from that? Is it something like GeforceNOW, but instead for games it is for AEC industry? https://www.nvidia.com/en-us/omniverse/architecture-engineering-construction/ Let's share som...
I'm creating some custom fixtures as objects, and would like to be able to maintain the added classifications across projects. Is there a way to imbed them in the object, or export/import? I created a custom classification set as in the attached, and...
It's complicated. At first we have Zones for Gross area and Rooms, which works fine for the Gross Area Schedule are the Zones are on different layers. BUT, placing Interior Elevations to read Zones is a problem when half the rooms say "First Floor Gr...
Yes, it indeed seems like a bug, I will report it to GRAPHISOFT.
Is there a tutorial on how to use the Aus Windoorbuilder? Its a handy tool but sooo clunky to use. A few tips would be good.
User | Count |
17 | |
6 | |
6 | |
5 | |
4 |
