Collaborate forum
Forum Posts
Assigning Custom PSets to ifcBuildingElementParts
I would like to assign PSets to individual layers of composites (e.g. to a layer in a slab consisting of concrete, insulation, screed and flooring). These elements are already being exported to IFC Schema as IfcBuildingElementParts. Archicad also all...
Linked moduls and stories
We have a main Archicad file and a hotlinked Archicad file where each story is a different modul in the main File.Each new modul has to come on a new story above. Sometimes it would be better to make a new story in betwen (to organise it better), but...
tjasa by Enthusiast
  • 172 Views
  • 3 replies
  • 0 likes
Exporting DWGs, then drawings move
both screenshots below are from an exported DWG file from AC25.the first one is a screenshot from Drawing Space where all drawings line up fine, as it was set up in AC.the second one is a modified arrangement, side-by-side & is not what we intended. ...
Edit loaded library path as string...?
Hi There, I'm effectively managing my team's libraries across both Windows and Mac however we don't use a server so libraries (and project files) are kept in Dropbox as opposed to being kept in a mapped network location. This is bad I know, but such ...
James HC by Contributor
  • 247 Views
  • 3 replies
  • 0 likes
Schedule Finishings Fields Missing
Good day, As I work with schedules in Archicad 25, I tend to include fields such as Floor, Wall, Ceiling Finish Tiltle. For some unknown reason to me, in a new project I've been working on, I imported a schedule layout exported from another project b...
SReinel by Newcomer
  • 140 Views
  • 1 replies
  • 0 likes
Resolved! Some opening lines not showing up in window schedule
Some of the opening lines in my window schedules are not showing up... not sure why. The opening lines are all showing up fine in elevations and in 3D. Maybe it's a bug? I have the same windows (different element ID) in the schedule but some opening ...
Yvonne by Enthusiast
  • 408 Views
  • 4 replies
  • 0 likes
SKETCHUP EXPORT OUT OF Archicad 26
I am having problems exporting from Archicad 26 (latest version fully updated) to sketchup (latest version fully update). The file crashes sketchup on opening. I have tried to export files with small simple geometry, and I have the same issue. I can ...
Nardo99 by Booster
  • 264 Views
  • 0 replies
  • 0 likes
What's up with BIMcomponents?
When I first started using this, it worked well. I could download stuff and log in and everything seemed great. At some point however something broke. The download link disappeared, and was replaced by the 'Drag to Archicad' option, which just doesn'...
