Collaborate forum
Forum Posts
Cadimage Keynote Manager in 10-Crashes...help!
When I brought an 9 project into 10 and loaded the new Keynote Manager it crashes Archicad each time I click on a view that has a keynote in it. It crashes ArchiCAD when I try to edit the keynote label. Any Ideas?? Is there a migration technique? P.S...
Anonymous by Not applicable
  • 3873 Views
  • 4 replies
  • 0 likes
PDF and Justify Text Alignment problem
In AC10, I have a couple of paragraphs of text in our titleblock (on a master) which is Justified. The last line of which (correctly) is not Justified (ie. it just ends where it ends). When I publish and/or print to PDF (Mac OSX) the paragraphs show ...
kevin b by Contributor
  • 2799 Views
  • 4 replies
  • 0 likes
publishing layouts
Open the Organizer, put layout book in left side, publisher on right side, drag and drop, publish.
  • 1933 Views
  • 1 replies
  • 0 likes
Export from ArchiCAD in Corel Draw (.cdr)
I need to export a floor plan from Archicad in Corel Draw. Already tried the bmp, psd, jpg option, but all these formats tend to blur the lines. Any ideeas will be greatly appreciated...i'm in a big jam here...
ICEdevil by Newcomer
  • 6448 Views
  • 1 replies
  • 0 likes
Door and window builder question
I have a project where I have been using double hung windows with door and window builder. The problem I am having is that I have not been able to find a way to have divided lites on the bottom sash. Does anyone have a solution to this? Thanks for an...
  • 9392 Views
  • 11 replies
  • 0 likes
Export from archicad to JPG / TIFF
I need help exporting from archicad to a jpg/tiff or any other file to use with Corel Draw. The problem is i can only obtain an image at very low dpi setting, no matter what i change...any ideeas will be appreciated Thank you, Dan
  • 22630 Views
  • 10 replies
  • 0 likes
Importing GIS
Does anyone out there know anything about importing GIS information into Archicad? File types are... .dbf .prj .sbn .sbx .shp Any help would be greatly appreciated. -Jared
  • 3696 Views
  • 2 replies
  • 0 likes
DWG file import---> problems (no lines at all)
I received a drawing from the consultant engineer but I miss to open it on both Archicad and PlotMaker (no lines visible). I tried the different options (ModelSpace, Paperspace with empty viewports, etc), with no visible results. However I am able to...
  • 11941 Views
  • 16 replies
  • 0 likes
