Collaborate forum
Forum Posts
Importing GIS
Does anyone out there know anything about importing GIS information into Archicad? File types are... .dbf .prj .sbn .sbx .shp Any help would be greatly appreciated. -Jared
Anonymous by Not applicable
  • 3764 Views
  • 2 replies
  • 0 likes
DWG file import---> problems (no lines at all)
I received a drawing from the consultant engineer but I miss to open it on both Archicad and PlotMaker (no lines visible). I tried the different options (ModelSpace, Paperspace with empty viewports, etc), with no visible results. However I am able to...
  • 12195 Views
  • 16 replies
  • 0 likes
Save As .dwg
Is there a dxf/dwg export plugin to save into R14 format for Archicad 9 and 10? My engineer cannot open my dwg because he has version 14. Thanks in advance. Rita
rengarch by Participant
  • 6895 Views
  • 10 replies
  • 0 likes
Bug Reporter
I have a G4 dual 450 Mac on OSX. I have been running ArchiCad 8 and plotting to an HP Designjet 430. Lately, when I try to plot I get the message the "TCP/IP network has not been selected." I know where to set this, just not what the number is. How d...
  • 1540 Views
  • 1 replies
  • 0 likes
PM9 Translator
I have tried every option to translate a file from PM to Autocad and all of them create a .dwg in decimal. How can I do that but translate to imperial?
  • 3746 Views
  • 8 replies
  • 0 likes
Scary calculation in OS X.4 Calculator
Trying to figure out why this happens and if it can have any impact on CAD. In the computers and systems I've been able to check out: OS X.3.# you go to the Calculator, type 200000 * 1.12 and get 224000. OS X.4, same thing, you get a weird 224000.000...
Ignacio by Advisor
  • 4088 Views
  • 4 replies
  • 0 likes
cadimage profiler
in one of the machines upgraded to ac10 we had cadimage profiler...now you open ac9 in that machine and the cadimage profiler gives an error and we cannot use ac9. the addons nightmare again...no more addon in our office
Import Steelwork models ?
Does anyone import steelwork models from other structural design programs and then use Archicad to build the building around them ? I work for a building contractor and we're currently researching the use of 3D models as both a marketing also a sched...
  • 3511 Views
  • 5 replies
  • 0 likes
