Collaborate forum
Forum Posts
Maxon Freeform in ArchiCad
"SPECIAL ANNOUNCEMENT – JUNE PROMOTION! Graphisoft and Maxon are happy to announce a new partner solution for ArchiCAD called FreeForm. Based on Cinema 4D, FreeForm allows users of ArchiCAD to edit elements of building models as parametric primitives...
Anonymous by Not applicable
  • 85669 Views
  • 111 replies
  • 0 likes
The Translator has disappeared
I tried to transfer object from 3dsmax in ArchiCAD. After that there was a failure In ArchiCAD. And already it has then ceased to be translated (that was not just) File from ArchiCAD in AutoCAD (DWG). That is does not emerge windows with the name Tra...
  • 1402 Views
  • 0 replies
  • 0 likes
version 6 :: back to the past
I recently transferred companies and have down graded from the luxuries of version 9 to the retro-vintage version 6. Our machines are not fast enough to handle a version higher than 7. I am passionately pleading for a technology upgrade to satisfy my...
  • 2057 Views
  • 1 replies
  • 0 likes
Plan2Model for AC9.0 for Mac OSX?
Does anyone knows if Plan2Model it´s available for Mac ? http://www.csoft.com/index.cfm?menuid=499 I saw this link.but I didn´t see if is for Mac Regards, David W
  • 4564 Views
  • 1 replies
  • 0 likes
ArchiStair problems
You're right. I've tried with new version and it works fine. I was using v1.9 with this new features unavailable. Don't know if you can help me with archistair. It doesn't work in my computer. I pass through all the creation dialog box, and when you ...
  • 13725 Views
  • 10 replies
  • 0 likes
data files now empty
As I was backing up to my external HD I discovered several files are now zero. I think it has happened before and I ignored it. My takeoffs work, but I don't understand why these 3 files... COMPDATA.TXT, DESCDATA.TXT and LISTKEY.TXT (under "MYPropert...
Apple switching to Intel..........Discuss
This is going to hurt us at first on the Mac side. I hope in the long run, it means faster machines at lower prices with the rock solid stability of OS X. http://www.macworld.com/news/2005/06/06/powerpcintel/index.php ...........discuss. Oh, Windows ...
rm by Advocate
  • 19018 Views
  • 19 replies
  • 0 likes
Color
we are used to be in Microstation, we have many color in drawings, but now is only black and white, is this for ArchiCAD? EY
  • 2889 Views
  • 4 replies
  • 0 likes
ArchiTime
Does anyone out there use ArchiTime. If so is it helpful?
Red by Enthusiast
  • 3447 Views
  • 0 replies
  • 0 likes
