Collaborate forum
Forum Posts
wall surface calculation
is there any possibility to calculate the wall surface using zone height instead of walls height? My walls go up through the slab and end on the next floor level. And when I try to calculate wall surf. (using zone list) there is a value for the whole...
Anonymous by Not applicable
  • 3755 Views
  • 1 replies
  • 0 likes
Revit Structure and ArchiCAD coordination
Good Afternoon, My firm is currently using Revit Structure and we are getting ready to do a project with a local architect who uses ArchiCAD. Has anyone here had any experience with trying to coordinate the 2 formats of models? I'm wondering if we'll...
  • 12667 Views
  • 14 replies
  • 0 likes
Autocad In Different Location
Ok…why is this happening….if I export a floor plan from AC to Autocad…..why doesn’t that Autocad file reference to the same point in AC later on….why are we loosing the coincidence of it’s location….this is frustrating....
  • 2043 Views
  • 2 replies
  • 0 likes
Schedule question
Any way to set up a schedule so it will do the following: One column will have ID nos. of a particular object. The adjacent column will have the quantities of that particular object on the plan. A grand total of all objects would be nice, but not nec...
ArchiStair How to Change Rise & Tread?
Hi, I posted this question to Cigraph with no luck of reply! How can I change an EXISTING created stair of 7" rise & 11 Tread to 8" Rise and 11" Tread? I can not modify the Rise? Thanks, Joseph
  • 5089 Views
  • 1 replies
  • 0 likes
converting help
Hi ! I would like to ask your help, as I got lost pretty well. I have to do a design work in Blender, but I did received the plans in ArchiCad .PLA file format. Usually, file format converting is a very easy thing, I usually use PolyTrans as one of t...
  • 2229 Views
  • 1 replies
  • 0 likes
Plotmaker 9 to DWG = Empty DWG?
When I pushlish a page of my layout book to .dwg format, it seems to publish just fine, but when I open the .dwg in archicad to check it ,I get a totally empty file. Any input? Whats up with that?
  • 4600 Views
  • 6 replies
  • 0 likes
How to make an AutoCAD Plotstyle file ?
Hello, I have started a freelance relationship with a 10 person Acad office run by a pretty flexible guy who I see as a potential future customer for ArchiCAD. At present, I do my work in Archicad and translate it to dwg. They are not keen on my send...
  • 7676 Views
  • 6 replies
  • 0 likes
Labels
