Collaborate forum
Forum Posts
Autocad In Different Location
Ok…why is this happening….if I export a floor plan from AC to Autocad…..why doesn’t that Autocad file reference to the same point in AC later on….why are we loosing the coincidence of it’s location….this is frustrating....
Anonymous by Not applicable
  • 2051 Views
  • 2 replies
  • 0 likes
Schedule question
Any way to set up a schedule so it will do the following: One column will have ID nos. of a particular object. The adjacent column will have the quantities of that particular object on the plan. A grand total of all objects would be nice, but not nec...
ArchiStair How to Change Rise & Tread?
Hi, I posted this question to Cigraph with no luck of reply! How can I change an EXISTING created stair of 7" rise & 11 Tread to 8" Rise and 11" Tread? I can not modify the Rise? Thanks, Joseph
  • 5095 Views
  • 1 replies
  • 0 likes
converting help
Hi ! I would like to ask your help, as I got lost pretty well. I have to do a design work in Blender, but I did received the plans in ArchiCad .PLA file format. Usually, file format converting is a very easy thing, I usually use PolyTrans as one of t...
  • 2241 Views
  • 1 replies
  • 0 likes
Plotmaker 9 to DWG = Empty DWG?
When I pushlish a page of my layout book to .dwg format, it seems to publish just fine, but when I open the .dwg in archicad to check it ,I get a totally empty file. Any input? Whats up with that?
  • 4631 Views
  • 6 replies
  • 0 likes
How to make an AutoCAD Plotstyle file ?
Hello, I have started a freelance relationship with a 10 person Acad office run by a pretty flexible guy who I see as a potential future customer for ArchiCAD. At present, I do my work in Archicad and translate it to dwg. They are not keen on my send...
  • 7740 Views
  • 6 replies
  • 0 likes
working with architerra
can you do solid element operations on a terrain? if not how do you create a clean model so walls and slabs are not just pushed into the terrrain, the plateau tool only allows a hole to have a vertical face of 89 degrees not 90. Any insight on archit...
  • 3441 Views
  • 0 replies
  • 0 likes
Export to DWG inconsistant
I'm having a lot of trouble trying to satisfy a AutoCad office I do a lot of documentation for due to some simple problems converting to DWG's. When I do bathroom and Kitchen layout, I place the tile pattern down then add the various elements over th...
Wokka by Newcomer
  • 4907 Views
  • 7 replies
  • 0 likes
