Collaborate forum
Forum Posts
PM Layout as dwg
PM Layouts do not allow one to Save as dwg, but one can Publish as dwg. However, the files I get that it creates can not be opened by PM or AC. PM says the file is empty and AC says nothing. Oddly, Adobe Illustrator can open them. AC on the other han...
MSotero by Participant
  • 13643 Views
  • 10 replies
  • 0 likes
Converting a file to dwg from ArchiCAD.
I have been trying to convert a project to a dwg file for my engineers for the past week and I keep getting an error messag - "cannot write output file". I have tried everything, please help. I am working on a Mac with version Panther and I currently...
Anonymous by Not applicable
  • 3745 Views
  • 1 replies
  • 0 likes
Merging From DWG Not Working
We have had a lot of problems merging DWG geometry into ArchiCAD. Sometimes it works, but more often than not 10-50% of the geometry is missing. I thought it might be a size issue so I had one of our guys split the DWG into two files, then merge each...
  • 4948 Views
  • 3 replies
  • 0 likes
Udating a library daily
I'm sure there is a program out there that could solve our problem. I think "My Briefcase" may have this option. When we load the library from our server it takes about 5 times longer to load than it would if it was on our local PC. How can we make s...
Red by Enthusiast
  • 3681 Views
  • 1 replies
  • 0 likes
Translator bug in 8.1?
I submitted a reply to another thread, but feel I need to start a new one on this topic. I am having trouble importing DXF files into AC 8.1 from Maya. I was able to do this with relatively no problems in AC 8, but after a fresh install of 8.1, SOME ...
  • 22855 Views
  • 23 replies
  • 0 likes
Document Accounting Solution for Architects
hi all, does someone knows a good software-solution to track print job costs by account (client / matter, project / phase, job number, department) for architects? we know "papercut" (www.papercut.biz) and the "canon document accounting"... but we are...
  • 10305 Views
  • 8 replies
  • 0 likes
publishing from plotmaker 3.1
When I publish from plotmaker 3.1 using the dwg/dxf translator going to a .dwg format. My fills in wall composites create a polyline where walls intersect. So I tried it with P.M 3.0 and it's fine. Can anyone help? I have to get dwg's to my consultan...
  • 3277 Views
  • 0 replies
  • 0 likes
Problems importing Autocad objects as library parts
I have a problem opening DXF objects as library parts. This problem has existed since version 8. Version 7 did not have this same problem. The problem relates to the DXF object arriving in as a library object incorrectly and slightly jumbled. I first...
  • 8497 Views
  • 7 replies
  • 0 likes
Possible xref bug?
Has anyone noticed that in 8.1 you can edit and even delete elements of an xref? If you update the xref everything reverts back to the contents of the external file. Conversely, you cannot do the same with hotlinked modules. I wonder if this is a fea...
  • 3747 Views
  • 1 replies
  • 0 likes
Converting files
Can a tif file be converted to a dxf or a dwg? If so what program do I need to use.
Red by Enthusiast
  • 5836 Views
  • 4 replies
  • 0 likes
