get alot of unreadable DWG/DXF drawings
I find a lot of my consultants cant read my DWG created from Plotmaker. They get a general error. I've turned off hairline and vectorial fills. At a bit of a loss
Has anyone imported from a surveyor using Autodesk Land Development Desktop (v3)? The surveyor says that the site info is contained in AAEC(?) objects created by the software. He is going to explode these into 3D polylines for me to try next, which I...
Dear Group I am trying to import an AutoCAD 2000 DWG or DXF (I was made both) which contains objects which, according to the author, are made in AutoCAD using solids. I have tried numerous ways to import the information to get these objects. But noth...
I am trying to create a site plan with ArchiTerra 2.0 newly released, and am runnning into problems with the way the tools are working as described in the manual versus the way they work for me, or don't work would be more apt to say. Has anyone had ...
Do we have knowledge regarding databeses and exporting tables from ArchiCAD. I know how to use the SQL-dialog for simple outputs of data, but I want to export these tables into a database. Then I can use Access to work with this data and simulate dif...
We recently purchased a CD with about 150 roofing details, and I would like to import that in as an Archicad library. I know you can export/publish several things at once. Is there any way to import several things at once? Thanks!! -Tom
This is a question from the "old" forum and I never got a chance to answer it before we all moved here. The problem I saw whas to connect to the ftp-server from within ArchiCAD, we used NT and couldnt create a directory like "my networkplaces in" XP....
HI!, I can't get my font translation to work. Althoug I state the substitutions to fonts I wan't, When oppend in Autocad, all the non Arial fonts are standard font. Any help on this one, please? Best regards, António Pina
User | Count |
11 | |
4 | |
4 | |
4 | |
3 |
