Collaborate forum
Forum Posts
Art*Lantis 5 beta tests to start this week
Author: bomer (---.fbx.proxad.net) Date: 12-15-04 22:07 Dear All, I am glad to annunce that the beta testing will start this week. It was a long and hard process, but finally we are happy to start a new step with .... about 100 ... experts and profes...
Screenshot to JPG Utility
Sometime last year, someone from tech support sent me a little utility that automatically created JPGs when doing a print screen. Unfortunately, a major crash sometime after that wiped out not only the installed utility but the email containing the f...
Anonymous by Not applicable
  • 7107 Views
  • 7 replies
  • 0 likes
DWG Scale Problem
I've been exporting to DWG so I can open up in Adobe Illustrator and so it fits inside Illustrator to a scale of 1:2000. The model in ArchiCAD is 3000m wide and 3000m high - masterplanning work. In the DWG Translator I'm setting the scale as 'Custom(...
James B by Graphisoft
  • 2019 Views
  • 0 replies
  • 0 likes
translator setup (import)
we are currently setting up translators to facilitate the import of consultants drawings (mostly dxfs or dwgs) into ac9. as we understand the standrad method is to assign a ac layer for every embeded layer. this however, seems somewhat limiting as it...
Wood Framing Plugin?
Around a year ago i read about a wood framing plugin for Archicad, and didnt see any threads out here discussing it. Is this still around, and if it is, is it any good? If not, how do i go about creating accurately framed residential buildings withou...
  • 28100 Views
  • 13 replies
  • 0 likes
.3ds export
For the experts - how do you change default settings, specifically for the .3ds export menu
  • 1804 Views
  • 0 replies
  • 0 likes
How do I deinstall ArchiTerra?
...I want to use ArchiTerra on another computer with another dongle... I copied all the ArchiTerra structure from the plug-in folder in AC to the other computer but when I'm trying to connect to serialize the AT version is "locked" to my original don...
  • 4903 Views
  • 3 replies
  • 0 likes
Missing vertex in ArchiCAD models?
Hi all, I'm new to AC and have just been playing around with it for a bit. I always render in 3ds max, so have been testing how compatible AC is with exporting to max. I have come across a strange problem, that when I have a wall with either 2 window...
  • 8983 Views
  • 11 replies
  • 0 likes
Change Default settings
When I save a 3d model, how do I change the default settings in the 3ds mode. Also when I hit save as, I would like .3ds to be the default, versus .psd Never had this problem in Archicad 8.1
  • 1688 Views
  • 0 replies
  • 0 likes
I/S 'user defined' voids zone name?
more I/S questions: 1. When I use the "user defined parameter 1, 2" etc in my schedules, in AC9 entering a note from within the 'list/preview/edit window' the Zone name, a column in my schedule used for room name, disappears from the schedule. Why? T...
