Collaborate forum
Forum Posts
Importing Autocad Solids into AC 8.0r3
Dear Group I am trying to import an AutoCAD 2000 DWG or DXF (I was made both) which contains objects which, according to the author, are made in AutoCAD using solids. I have tried numerous ways to import the information to get these objects. But noth...
tsturm by Newcomer
  • 18165 Views
  • 14 replies
  • 0 likes
ArchiTerra 2.0
I am trying to create a site plan with ArchiTerra 2.0 newly released, and am runnning into problems with the way the tools are working as described in the manual versus the way they work for me, or don't work would be more apt to say. Has anyone had ...
Jacek by Contributor
  • 29667 Views
  • 26 replies
  • 0 likes
The model as a base for cost calculations
Do we have knowledge regarding databeses and exporting tables from ArchiCAD. I know how to use the SQL-dialog for simple outputs of data, but I want to export these tables into a database. Then I can use Access to work with this data and simulate dif...
eldhead by Newcomer
  • 6717 Views
  • 5 replies
  • 0 likes
Batch import?
We recently purchased a CD with about 150 roofing details, and I would like to import that in as an Archicad library. I know you can export/publish several things at once. Is there any way to import several things at once? Thanks!! -Tom
TomWaltz by Newcomer
  • 4129 Views
  • 2 replies
  • 0 likes
TeamWork through FTP
This is a question from the "old" forum and I never got a chance to answer it before we all moved here. The problem I saw whas to connect to the ftp-server from within ArchiCAD, we used NT and couldnt create a directory like "my networkplaces in" XP....
eldhead by Newcomer
  • 5356 Views
  • 3 replies
  • 0 likes
Converting Fonts to Autocad
HI!, I can't get my font translation to work. Althoug I state the substitutions to fonts I wan't, When oppend in Autocad, all the non Arial fonts are standard font. Any help on this one, please? Best regards, António Pina
Anonymous by Not applicable
  • 33711 Views
  • 21 replies
  • 0 likes
Labels
Most liked authors
