Collaborate forum
Forum Posts
The model as a base for cost calculations
Do we have knowledge regarding databeses and exporting tables from ArchiCAD. I know how to use the SQL-dialog for simple outputs of data, but I want to export these tables into a database. Then I can use Access to work with this data and simulate dif...
eldhead by Newcomer
  • 6727 Views
  • 5 replies
  • 0 likes
Batch import?
We recently purchased a CD with about 150 roofing details, and I would like to import that in as an Archicad library. I know you can export/publish several things at once. Is there any way to import several things at once? Thanks!! -Tom
TomWaltz by Newcomer
  • 4138 Views
  • 2 replies
  • 0 likes
TeamWork through FTP
This is a question from the "old" forum and I never got a chance to answer it before we all moved here. The problem I saw whas to connect to the ftp-server from within ArchiCAD, we used NT and couldnt create a directory like "my networkplaces in" XP....
eldhead by Newcomer
  • 5364 Views
  • 3 replies
  • 0 likes
Converting Fonts to Autocad
HI!, I can't get my font translation to work. Althoug I state the substitutions to fonts I wan't, When oppend in Autocad, all the non Arial fonts are standard font. Any help on this one, please? Best regards, António Pina
Anonymous by Not applicable
  • 33744 Views
  • 21 replies
  • 0 likes
