Collaborate forum
Forum Posts
Saving to R14 dwg
I am having trouble concisitantly saving to R14 from both AC and plotmaker. Once in a blue moon it works. The same drawings from either convert perfectly each and everytime to with the R2000 translator. I've been through the various settings. What am...
Publish question
In the View Set Publishing Properties, choosing Upload to internet... How can I create a Host Name? The user name and the password should have to be different than the Teamwork?
Anonymous by Not applicable
  • 2768 Views
  • 0 replies
  • 0 likes
!Restored: Architerra
Can anyone explain what the points are in architerra. I am considering buying it. I want to be able to generate a report or list of distance and bearing from the origin or other point. This list would then be sent to our total station to use as const...
  • 13595 Views
  • 17 replies
  • 0 likes
X3D Translations
Following from my last post about DXF translators here is another. Can Archicad import an X3D file. I've checked the usual sources and can't find how to do it. Nor, it seems, is X3D a very common format. Any suggestions? If not, I'll have to get my c...
KeesW by Advocate
  • 4031 Views
  • 1 replies
  • 0 likes
DXF Translator
I've loaded Archicad v8.1 and am needing to import a DXF drawing. Unfortunately, my translator attributes do not include 'Fills (save methods)" as described in the Archicad User Guide Vol 2 page 150. Is there a setting I've missed?
KeesW by Advocate
  • 7054 Views
  • 6 replies
  • 0 likes
Exporting (Saving As) Model as a dwg
I have been asked to send a 3D Model of a project to another Architectural firm using Autocad 2002. Been able to send 2d stuff to engineers but have never tried 3d information. Is this possible? and if so what are the steps. Thanks. Jim
  • 6767 Views
  • 6 replies
  • 0 likes
Exporting CAD for desktop publishing
Could anyone give advice on how best to export/process CAD files for use within desktop publishing programmes, AND achieve fine print quality of the sort seen in the journals. I'm familiar (ish) with using EPS, although I use Illustrator to create an...
  • 6168 Views
  • 3 replies
  • 0 likes
Importing Microstation 8.1 files
Our dealer tells us that Archicad will not be able to import the new Microstation 8 file format until the next version of Archicad. Aside from buying a $3-4000 program just for translations, has anyone else out there had to deal with this issue?
TomWaltz by Newcomer
  • 5413 Views
  • 2 replies
  • 0 likes
Exporting files
How do you export something from Archicad as a tif but with a high resolutiuon of 300 dpi? Where can you state how high you want the resolution???
  • 5582 Views
  • 8 replies
  • 0 likes
