Collaborate forum
Forum Posts
Updating Zone Schedule
Howdy,I've created a schedule to get the wall surface area's using zones (attached is the criteria).However, when the wall heights (square footages) are modified, the schedule doesn't update, I have to close the schedule and re-open it... What am I m...
pbg by Contributor
  • 212 Views
  • 1 replies
  • 0 likes
Resolved! IFC export
When trying to export my model to IFC, a mistake happens with the some of the walls, that are cut to roof. The roof that is used to cut the walls is reaching to their external edge. While some of the inner walls seem to export ok, that is not the cas...
Katja_Z by Participant
  • 348 Views
  • 2 replies
  • 0 likes
Automatically reserve teamwork
Hi all,Ive got a question about reserving elements in a teamwork file. The person I work with, often reserves his elements via the reserve button in the teamwork panel. Very often he reserves everything instead of the elements he selects. What is tha...
Resolved! Unable to connect to Graphisoft ID server
Got this error message when trying to open Archicad. Had no issues before today...Internet connection works fine and working in Archicad 25 on a windows pc. Anyone know how to fix this?  
Yvonne by Enthusiast
  • 303 Views
  • 2 replies
  • 0 likes
DXF-DWG TRANSLATOR FROM 25 TO 24 ISSUE
I use Archicad 25.I have a client that uses Archicad 24 and he asked me to send him a file to make some extra changes.He asked me to send him the dxf-dwg translator that I use in my file but when I sent it he couldn't import it.Is this because he has...
st by Contributor
  • 329 Views
  • 4 replies
  • 0 likes
Archicad 25 teamwork crashes
Hi! I have a problem with my Archicad teamwork file. It crashes while opening but this only happens to me and this specific file. I can open other teamworks files and my colleagues can open this file as normal. Has someone a solution for this? I use ...
