Collaborate forum
building a wall from scratch
I am trying to design a wall with several components, the concrete part juts out at an angle and then comes straight down. It also has a curtain wall window about 3 feet above the bottom of the concrete. Is there a way to build the wall as a new family (maybe by creating a profile of the wall?). Any help on this would be appreciated.
5 REPLIES 5
btw, I'm working in Revit
Someone might answer you here, but really you should find a appropriate place to post your questions regarding revit, which is not here.
good luck
lec
Change to Archicad. Use a Complex Profile
Revit forums are found at http://www.augi.com
They can help you there.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Another useful Revit forum can be found at www.revitcity.com
Labels
