Collaborate forum
camera movement once exported to artlantis
hi basically im rendering using the sketch engine and after this i want to keep the exact view i have from archicad and put it into artlantis. after i do this i find the camera has moved and is out of place. the only reason i export it into artlantis is because of the better material shaders and better sun and lighting once renders.
would you recommend virtual building explorer??? im after a sketchy render but with slight colour and texture?????
1 REPLY 1
One common practice is to use the internal or LightWorks engine and overlay the resulting color rendering with the sketch render in Photoshop.
Labels
