2017-10-24 01:19 PM
2017-10-28 08:51 PM
2017-10-29 12:58 PM
laszlonagy wrote:Thanks, Laslo. There was a problem there (attached), and I had to reinstall ArchiCAD o fix it. I noted as I reinstalled the update (ARCHICAD-21-Update-4022-1.2) that the 'export to Twinmotion' Add-on is now not functioning. I wonder if it is something with the update install throwing this off? But I have been syncing to TM, so I'll leave that alone for now.
Activate the Options\Add-On Manager menu command to open the Add-On Manager Dialog.
Check to see whether the "DWG/DXF Input/Output" Add-On is listed among the Add-Ons. Also make sure that the checkbox before it is checked in the Dialog.
I suspect it is either not their (then you may need to re-install ARCHICAD), or the checkbox is not checked (then check it and you may need to restart ARCHICAD for the commands to appear on the menu).
A third possibility is that you menu is migrated from am earlier ARCHICAD version or another Work Environment where the command were not there. In this case you need to go to the Work Environment Dialog and add the commands manually to the menu.
