2008-10-04 04:03 AM
2008-10-04 10:29 AM
ale-la wrote:Create a new database.
in the edit Database dialog there are the "Default Set", "AC_12_Int", "RoofMaker 2.1". If you select "AC_12_Int", the option "Dublicate" is not enabled. However the lower level options as i.e. "General", Sitework" etc. can be dublicated. Is there any way to clone the entire database before I start making extended changes, or at least have a backup copy of the original "AC_12_Int" database ?
The "Default Set" does not seem to contain something, what is it's use?
